IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
98' S70 Turbo, Hesitation when accelerating and running lean
Moppman
Year and Model: 98 S70 GLT
Post by Moppman »
So, I was here a few months ago with an issue that my car was running really rich when the maf was connected. Well after all this time I noticed the intercooler housing was completely broke open. So today, using a CPVC plug and a lot of JB, I plugged the massive hole up. I then connected the Maf up, doing the zip-tie trick and everything, reset the ecu by disconnecting the battery for 15 minutes. Then I did the "reprogram" technique of letting it idle for a few in P then in D then drove at about 30% throttle for a while. When hitting the accelerator after letting off of it, it'd massively hesitate. I'm talking a 1-2 second pause before it'd accelerate, but when it did it seemed fine and had power. No check engine light, but got codes read anyway and pulled up the code saying it's too lean. So I tried driving without the MAF again and drives great and has good power. I've replaced the MAF twice now so I know that's not what it is. I know it's a lot to follow, but any advice would help. My car has a lot left in it and I want to keep it healthy but taking it to a Clinic or Dealership for a $80+ diagnostic fee and then the service is much more than I want to pay when I could possibly fix it myself. Thank you very much.
2.4L Turbo
127K Miles
87 Octane
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 378 times
Been thanked: 1185 times
Re: 98' S70 Turbo, Hesitation when accelerating and running lean
What codes do you get exactly? The p Code will help You track the fault.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 45 times
Been thanked: 182 times
Post by bmdubya1198 »
Get the codes scanned for free at Autozone if you don't have an OBD2 scanner. That will be the best first step to take here. It sounds sensor-related.
Also, I would stop using 87 octane in a turbo Volvo. Up it to 93... 87 burns valves.
'00 V70R Venetian Red/Charcoal M56 Swapped 199k
'03 S60 2.4T Silver/Black 117k
'07 XC90 V8 AWD Sport Titanium Grey/Black 174k
'91 944 Turbo Dark Green/Beige 175k
'92 245 Base White/Beige 249k
'99 BMW 528i
'01 Mountaineer 5.0
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
Moppman
Post by Moppman »
abscate wrote: Sun May 21, 2017 8:02 pm What codes do you get exactly? The p Code will help You track the fault.
I don't remember the exact code, something along the lines of p0170 or p0171 but the description was "system too lean."
Moppman
Post by Moppman »
bmdubya1198 wrote: Sun May 21, 2017 8:56 pm Get the codes scanned for free at Autozone if you don't have an OBD2 scanner. That will be the best first step to take here. It sounds sensor-related.
I did have them checked, that's why I made the posit. I don't remember the code. But it was something like p0171 and the description was "system too lean"
You've still got vacuum leaks in the induction after the MAF
rspi
Has thanked: 22 times
Been thanked: 50 times
Post by rspi »
1. Where did you get the MAF?
2. What brand is the MAF?
3. Is the PCV system serviceable?
4. Did you have the intercooler pressure tested to make sure it doesn't have any other leaks?
'95 855 T-5R M, Panther - 22/28 mpg
'98 S70 GLT, Lil' Red 25/32 mpg
