IPD sale XeMODeX - Experts in Volvo Electronics Volvo modules repair and programming
Please use the MVS Amazon link when you buy anything at all! It helps this site. Thanks very much!
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
1996 850 T5 Turbo Windshield Washer Fluid Leak
850 Turbo1
Year and Model: 1996 Volvo 850
Post by 850 Turbo1 »
Hi Everyone,
So here is my conundrum. Every time I fill my washer fluid, the low washer fluid comes on about a week later . I started thinking that I might be using too much. I put the car on ramps and filled the washer fluid with water...low and behold...waters starts leaking from the bottom. Is this the reservoir leaking...or could it be something else?
I have Volvo Vadis but can't seem to find the repair section for this. Has anyone else had this problem. If it was the summer I'd just use straight water, but it's the winter and we are dealing with below freezing temps.
Thanks!
1996 850 T5 Sedan
1996 850 T5 Platinum Edition Wagon
--Always Learning--MB--
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 10 times
Re: 1996 850 T5 Turbo Windshield Washer Fluid Leak
Post by jblackburn »
The reservoirs crack & start to leak, just like the coolant reservoir and power steering ones do. I don't know what plastic they made these things out of, but it's not very good.
Try to track the leak down further (pulling off the air guide may help), and I'll try to find you something about how to get that thing out of there - I know the bolts are somewhat hard to find.
'98 S70 T5
2016 Chevy Cruze Premier
850 Turbo1
I don't have an air guide on mine. I was under it recently and I couldn't even see the reservoir,just the dripping. This is frustrating :cry: :?
I'll keep looking as well for a repair guide or something to help.
Thanks Justin!
1996 850 T5 Sedan
jblackburn
Well, not a repair guide, but they describe the location of the screws pretty well.
http://www.matthewsvolvosite.com/forums ... =1&t=25996
And apparently they found it in VADIS too, there's a diagram there :mrgreen:
That software is really hard to use...I haven't figured it out entirely myself yet either, so don't feel bad :mrgreen:
'98 S70 T5
850 Turbo1
Replacing washer reservoir
Removing
Remove:
-washer reservoir filler pipe.
-windshield washer pump, rear windshield washer pump (5–door) and level sensor connectors.
-washer reservoir screws.
-washer reservoir.
-hoses.
-level sensor, pull up.
-windshield washer pump, pull out from underneath the car. (A)
-rear windshield washer pump (5–door), pull up. (B)
Installing
Install:
-rear windshield washer pump (5–door), press carefully into place. (A)
-windshield washer pump, install from underneath the car. (B)
-level sensor, press carefully into place.
-hoses.
-washer reservoir.
Note! Before installing pump, immerse intake pipe in water or a soap solution to avoid compressing the rubber seal.
-washer reservoir filler pipe. Fill washer bottle with water and check that the pumps, level sensor and filler pipe are correctly connected to the washer bottle.
Thanks --This came straight from Volvo Vadis...It was under the electrical section..haha go figure!
1996 850 T5 Sedan
anmartin44
Year and Model: 1994 850 n/a
Has thanked: 2 times
Been thanked: 2 times
Post by anmartin44 »
you dont need to take off the airdam to get to the resivior. its the big white tank in the very front passenger corner. it should be right in front of the FR wheel well. i think its just a couple of torx screws and then it comes out from the bottom. mine is leaking from somewhere too but i've only investigated it and not tackled it yet.
good luck,
andrew
1994 850 na green 187k on body, 275k on motor(backwards?), unrestricted airbox, 960 TB, persus wheels, Lowered, IPD poly upper and trans mounts.
1974 144 k-jet m40 satin black, 250k on body, 25k on rebuilt motor(running...usually)
850 Turbo1
Ok I'll just take it out and repair it I think. I'll take a photo if possible.
1996 850 T5 Sedan
850 Turbo1
The windshield washer fluid reservoir tank when out of the car.
1996 850 T5 Sedan
polskamafia mjl
Has thanked: 10 times
Been thanked: 9 times
Post by polskamafia mjl »
I'm glad I'm not the only one w/ this problem. I was wondering why I was always low on washer fluid.
