IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
S70 not accelerating
asammy
Year and Model: S70, 2000
Has thanked: 0
Been thanked: 0
asammy
Post by asammy » Wed Nov 21, 2012 4:13 pm
hey guys,
I have a 2000 S70 (not turbo) with 203,000 km. Recently (past month) the car has not been accelerating properly. It started off once a week, then more frequently. I changed the spark plugs, and air filter today, and now it is happening all the time. The car revs high, but does not go. It takes about a min. to hit 50km/hr.
I bought this car from my sister in law back in July, had the timing belt replaced at my local volvo dealership in August, at 197,000 km.
Any help would be greatly appreciated. I'm totally lost with this car. I had a ford ranger before, and everything with that was dirt simple to troubleshoot and repair.
Oh and here is the best part. No engine light is on... :o
please HELP!
Thanks
Andrew
Vtech
Year and Model: 1997 S90
Has thanked: 0
Been thanked: 0
Vtech
Re: S70 not accelerating
Post by Vtech » Wed Nov 21, 2012 5:02 pm
Hello , it sounds like your transmission is slipping , please check the fluid level before driving any more and if it is low top it up before driving . see owners manual for proceedure . If fluid is dark or black then drain and refill - takes 3.5 - 4qts . should use volvo fluid or good quality synthetic like Redline D4 ATF . You might have to drain and fill several times to get enough clean fluid in the total trans . If it is not low or flushing the trans does not help (and it acts like it is in neutral when in drive) then you have serious trans problems and need a replacement unit. Good luck , Larry
Matty Moo
Year and Model: 850, 1996
Has thanked: 0
Been thanked: 14 times
United States of America
Matty Moo
Post by Matty Moo » Wed Nov 21, 2012 5:43 pm
What lights are on, as in trouble lights on the dash. Cel, ets, etc.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
asammy
Has thanked: 0
Been thanked: 0
asammy
Post by asammy » Wed Nov 21, 2012 6:40 pm
Matty Moo wrote:What lights are on, as in trouble lights on the dash. Cel, ets, etc.
There are no lights on, except for washer fluid. There were lights on before this issue, took it to Muffler Man, but their machines could not read the Volvo for some reason. The lights turned off a week ago, after i replaced the stock CD player, with an aftermarket one.
Andrew
asammy
Has thanked: 0
Been thanked: 0
asammy
Post by asammy » Wed Nov 21, 2012 6:45 pm
Vtech wrote:Hello , it sounds like your transmission is slipping , please check the fluid level before driving any more and if it is low top it up before driving . see owners manual for proceedure . If fluid is dark or black then drain and refill - takes 3.5 - 4qts . should use volvo fluid or good quality synthetic like Redline D4 ATF . You might have to drain and fill several times to get enough clean fluid in the total trans . If it is not low or flushing the trans does not help (and it acts like it is in neutral when in drive) then you have serious trans problems and need a replacement unit. Good luck , Larry
Larry,
I tried checking the transmission fluid today, when I was under the hood changing the spark plugs, but I could not locate the dipstick for it. I feel like a newbie after not being able to locate it. I referred to the owners manual, and looked up the location of the dipstick, but I cannot find it still. I'm not claiming to be a mechanic, but between me and my brother, we have ripped apart both of our Rangers, multiple times, and neither of us could find this dipstick. Having a blonde moment
Andrew
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 604 times
Been thanked: 251 times
matthew1
Post by matthew1 » Wed Nov 21, 2012 8:01 pm
http://www.matthewsvolvosite.com/images ... ne_bay.jpg
Many users have trouble finding it. That big image with the transmission dipstick location arrow is probably 8 or 10 years old... it was among the first ever 850 help photos I put up. Same location on S70s.
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
