Found a little hole on the top of my coolant expansion tank. The hole is small. What could happen to the cooling system?
Also can I just use regular hose clamp for the bleeder hose? Didn't find the clamp from Fcpgroton.
Thanks in advance!
A hole on the top of coolant expansion tank
el diablo viejo
- Year and Model: 98 S 70 T5 Stick
I have had the occasion of being to two boneyards this week and almost every Volvo I saw still had the expansion tank still on it, although many were missing the cap.
My advice would be to just go pick up a used reservoir tank and grab another Volvo clamp while you're at it.
For the couple of dollars it's not worth having to think about a hole in the tank.
When you pull off your old reservoir tank, check the bottom hose. I found mine had been rubbing against the large air hose underneath it and consequently had been worn thin in one spot. I think this is common on the S/V 70 setups.
1998 S70 T5 5 spd. 196 K Amsoil
1969 442 Amsoil
Long gone 1985 242 4spd.
Long long gone 1966 122 4 spd.
Way long gone 1961 PV 544 4spd.
1969 442 Amsoil
- Year and Model: Many Volvos
- Been thanked: 76 times
A new replacement isn't that expensive, I just had to buy one for my daughter's S70 and I think it was under $30.00. Standard worm gear hose clamps are just fine on both hoses.
The new tank had reinforced tubes on both the main hose and the bleeder hose, all of mine have broken at the bleeder hose nipple so the metal reinforcement is a huge upgrade.
Running without the system getting up to pressure can allow the coolant to boil which, in the popular vernacular, is a "Bad Thing".
Also check your cap, the old Gray caps all split but the new style Greenish Blue caps seem to hold up. They too are cheap in Volvo terms.
Thanks for the information. New tank for 99-00 V70 seems to be a little bit more expensive at ~$40 plus shipping. Good thing is that my current cap is green, so I guess the cap and the bleeder hoses might have been replaced before, thus I'll just order the tank itself. The hoses feel solid still to me. Thanks again.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Is the low coolant light on? As long as the float isn't sitting at the bottom of the tank and tripping the sensor, I don't know that it matters.
'98 S70 T5
2016 Chevy Cruze Premier
Yes, the coolant light is on. The float isn't at the bottom, so that means the sensor might not be installed correctly? I heard a clip when I put the sensor in the hole so I assumed it snapped in.jblackburn wrote:Is the low coolant light on? As long as the float isn't sitting at the bottom of the tank and tripping the sensor, I don't know that it matters.
db130
- Year and Model: 2002 V70 T5
i'm sure there is, but the fact that the light is on even though the float is working correctly is a dead giveaway.
*edit - take the sensor out of the socket on the expansion tank but leave it plugged in - is the light still on? most likely it will be, because it has died.
the light should only come on if the float comes close enough to the sensor
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
2002 V70 NA 249k
- 911 Views
Last post by tryingbe
- 12 Replies
- 2838 Views
Last post by precopster
- 734 Views
- 436 Views
- 1061 Views
Last post by Pretribrapper
