the rack an pinion is leaking on the pass. side at the end on the rack, is it as straight forward as every other car or are there some things that will help me from frustration? im sure i will have to lower the engine a little from the sub frame mounts, if there is no diy ill try and make one if i remember to take pics when while doing this.
thx
any diy for rack and pinion?
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
check out the Repair Database above; suspenion-parts list (left-side of screen), continue reading, Volvo 850 Front Susp Rebuild, Front Driveshaft Remove + Replace, this will be under (matthew1>>14 DEC 2005...with pictures. Hope that gets you started.
98 S70 T5-M Brick for life
confused_al
- Year and Model: 1996 TLA wagon
HTH
http://volvospeed.com/volvo_repairs_how ... rvice.html
PDF version:
http://volvospeed.com/pdf/power_steering.pdf
PDF version:
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
wow thank you both, i was not expecting a quick response, the leak is not bad to the point of dripping on the ground but when the car is running there a lots of boubles, it makes alot of noise, maybe i will try some new fluids,
thanks again for the help
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
If it is not leaking yet, try this first: suck out all of the fluid in the reservoir with a turkey baster. Replace with new (this system takes Dex-III TRANSMISSION fluid - don't use power steering fluid!!!), and run the steering lock to lock a few times. Siphon out, and repeat til all the fluid in the reservoir is a bright, clear red.
'98 S70 T5
2016 Chevy Cruze Premier
- Has thanked: 311 times
- Been thanked: 817 times
I agree, this worked with a rack that had been leaking for almost 2 years: drained and replaced with Mobil 1 synthetic ATF, then it was leak-free for about 3 years. Then the leak came back, I ran it for another 6 months that way until I had the engine out. At that time I replaced the rack with a rebuilt one.
- 1200 Views
- 1284 Views
Last post by oragex
- 464 Views
Last post by stevolvos60
- 525 Views
Last post by j-dawg
- 1465 Views
