IPD sale Volvo Parts
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
Identifying stop-neutral presence
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
MattHenning
Year and Model: XC70, 2001
Has thanked: 0
Been thanked: 0
MattHenning
Post by MattHenning » Sat Mar 16, 2013 7:59 am
I was able to see that my 2001 V70XC still has the stop-neutral feature at 175,000 miles while troubleshooting another problem. Here's how a was able to determine its presence. In VIDA, I created a visual display of the engine speed and transmission input speed. In neutral or park, the two speeds should be nearly identical. When the transmission is put in gear with the car not moving, the transmission input speed should go to zero as it is now, via the transmission, connected to the output shaft. When coming to a stop while driving, the transmission input speed should drop to zero and stay there as long as the car is stopped. If, as in my car, the stop-neutral feature is present, the transmission input speed will drop to zero but shortly after, while still stopped, it will jump up to the same speed as the engine. This shows that the transmission has been put in neutral.
I have read a number of posts regarding how to determine whether a car still has stop-neutral. This seems like a pretty sure-fire way to do it.
Needless to say, I will be visiting the dealer to update the software as soon as I correct the other problems with the car. I hope they don't give me the run-around.
JRL
Year and Model: Several
Has thanked: 0
Been thanked: 10 times
United States of America
JRL
Re: Identifying stop-neutral presence
Post by JRL » Sat Mar 16, 2013 9:17 am
And it's still in one piece, absolutely amazing
Contact info for purchases: [email protected]
precopster
Year and Model: Lots
Has thanked: 4 times
Been thanked: 93 times
Australia
precopster
Post by precopster » Sat Mar 16, 2013 9:48 pm
He's a 5%er. They ARE out there!!
My 2000 P80 series had the neutral stop until November 2011 until I had it removed though after B4 cover, new JWS 3309 compliant synthetic fluid (Nulon Full Synthetic Multi Vehicle Fluid) and adapts as well as fuid counter reset it only plays up when hot or when engaging drive (delayed)
It now has 275,000 kms and is still going strong. Hope it gets to 350,000kms; I think that would be quite an achievement :)
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
mikealder
Year and Model: V70 2000
Has thanked: 0
Been thanked: 2 times
mikealder
Post by mikealder » Sun Mar 17, 2013 3:57 am
With the car in Drive apply the handbrake next apply and release the footbrake a few times, can you feel the car going in to drive as you release the footbrake, the car won't move but you can usually feel the drive engage even when it is working as intended, if you can feel the drive engaging when you release the footbrake then the stop Neutral is still activated, if you can't feel it then it is probably disabled/ removed - Mike
regent
Year and Model: 2015 XC60 T5
Has thanked: 1 time
Been thanked: 5 times
regent
Post by regent » Sun Mar 17, 2013 9:12 am
In VIDA, if you can place the TCM in test mode or adaptive mode, you do have the updated TCM firmware.
Also, when you read the car, you will see that neutral control is not there.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
JRL
Has thanked: 0
JRL
Post by JRL » Sun Mar 17, 2013 9:58 am
No GEN 1 (P80) came with stop neutral
mikealder
Has thanked: 0
mikealder
Post by mikealder » Sun Mar 17, 2013 10:04 am
Perhaps JRL is correct for US Spec cars but my V70 Phase One built March 2000 with the five speed auto box has Stop Neutral and it works so I haven't bothered getting it disabled - Mike
regent
Has thanked: 1 time
regent
Post by regent » Sun Mar 17, 2013 12:51 pm
Yes, talk to her with VIDA and she will confess.
2015 BMW 335i
precopster
Australia
precopster
Post by precopster » Sun Mar 17, 2013 2:09 pm
My P80 NA definitely had it also and it fitted the description perfectly; leave her in Drive, come to a stop and see the revs rise as the car shifts into neutral about 5 secs later then settle to normal speed. Then when revs rise to about 1,000 by throttle application you would feel the car go back into Drive (as if somebody grabbed the lever and pushed it back into D from N) as revs slightly dipped and the car moved forward. On slight inclines the car would roll back until the gear engaged. If you let go of the brake on an incline without raising revs you would eventually roll into the car behind you. In some rather steep inclines I would engage the handbrake as I disliked the sensation of not being in control. Where the valve body is already in some distress due to wear as mine is it would seem to take forever to engage gear. By that time revs rise to higher RPMs and I would get a bang on take-off.
I was so relieved when the dealer did the TCM upgrade but I still had lots to do until flares and banging were reduced.
JRL
Has thanked: 0
JRL
Post by JRL » Sun Mar 17, 2013 9:23 pm
mikealder wrote:Perhap... I haven't bothered getting it disabled - Mike
Not too smart. You know what it can do and eventually will do...KaBOOM!
