v70r AWD conversion to FWD
trevlockwood
Year and Model: v70 1998
Post by trevlockwood »
I'm a real newbie to all of this, just wondering if anybody could direct me to any links for converting my V70 1998 to a FWD and has anybody had first hand in doing this, reading some posts on other forums that it is as simple as just removing the driveshafts, i would be extremely grateful for some info from anybody who has done this.
cheers guys
trev
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
This is probably the topic you were looking for:
98 v70 xc drive shaft removal
It really is as simple as just removing the driveshaft.
'98 S70 T5
2016 Chevy Cruze Premier
renns
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 6 times
Post by renns »
trev,
If your bevel gearbox is functioning properly, then simply removing the driveshaft will work. If you are experiencing noise from the bevel gearbox, then removing the driveshaft may not resolve the problem. There are options to remove the bevel gearbox permanently as well, but it requires that the drive collar be somehow locked into the transmission to properly seal it from the elements and prevent oil leakage. Here's a thread that discusses some options if full bevel gearbox removal is needed.
http://forums.swedespeed.com/showthread ... WD-Removal
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
